Stoneage_Turbo »
https://forums.nicoclub.com/stoneage-turbo-u133.html
Thu Jul 31, 2003 10:22 am
i dunno cold , its a turbo , id think on a hot day youd dentonate on 87 , but i dont know much about subaru turbos , id say to do it, timing and boost would have to be trimmed back like i say tho my turbo experence is sevrely limited, esp in hot climates
its too bad i have to use preimum , the savings would be great
my caddy has has to have premuin due to the fact it doent have a knock sensor , the computer flys blind when it comes to ping , it doesnt know if its pinging or not so the timing cant be changed around to the fuel requirements , instaed it uses the egr system to remove excess unburned fuel as told to the ecu by the o2 sensors , and temp signals from air intake temp and coolant temp senors,in turn crudely trying to controll ping that the computer knows nothing about. a stupid way to go around haveing a knocksensor , but a good way to make sure caddy owner only use premium so the oil companys stay happy
cant wait to grab another G20
