Premium Bose Bluetooth problems
08Coupe
Car: 2008 Altima Coupe
This problem happens on both my iPhone 3G and Blackjack (AT&T).
If I answer an incomming call too quickly from the steering wheel, the radio locks on "1 second call display" also causes the call to drop and the worst part doesn't hang-up the call at the radio...anotherwords locked on a 1 second call. You can't shut off the call, use the radio or even shut the radio off!!! You have to restart the car and on the highway this sucks! Making a call from the phone doesn't work because it sends it to the non-working bluetooth of the car, so to make a call you have to disable bluetooth at the phone and use the phone without bluetooth, until you can restart the car.
Anyone else have this problem? Is there a fix? thanks
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
ahh....no. Bluetooth works fine for me and I'm using the crackberry world edition. Sorry to hear you're having problems man
marlin29311
Car: 2008 Infiniti G35x
It's possible that those two phones aren't compatible with the bluetooth unit in the car. My suggestion is to un-pair them, retry each one individually, and see if that doesn anything.
08Coupe
marlin29311 wrote:It's possible that those two phones aren't compatible with the bluetooth unit in the car. My suggestion is to un-pair them, retry each one individually, and see if that doesn anything.
I did It doen't happen all the time, and never if I answer the call from the phone or make the call...It also only happened 3 times, all when on the highway lol..I mainly use my iPhone but when it happened to the blackjack I figured it was the radio... The not being able to shut off the radio 'in a call" is strange
FYI you can shut off the car at 80mph and restart it with the button with a simple break tap
windex
Car: 2008 Altima Coupe 3.5SE
Just be glad you dont have a tilt... I can't use my phone with my bluetooth.... Anyways I thought both of those phones were compatible, check http://nissanusa.com/bluetooth to see if they have passed testing.
Lundarius
Car: 2008 Altima Coupe 3.5 SE
I have the exact same issue, I bought the car in Dec 07, and they told me no one else has this issue and it has yet to be fixed.
