naed240sx wrote:
Sorry man, but you are kind of talking out of your *** here. You don't need equipment to add preload in a beneficial way to a car. If you happen to be hitting the bumpstops, you should add preload.
Also, adjusting bumpstops? huh? That's not possible.
First of all, why would you adjust preload with the coils off the car? Why would you turn them upside down? None of this is neccesary or helpful. Preload can be adjusted or zeroed just fine with the coils on the car.
To Bosrudorfer: Drooping spring causes accelerated damper wear, and usually affects handling in a negative way. Do not droop unless the height adjustment is as low as it will go. Drooping if the lower mount is not at the lowest possible position is stupid, because lowering via the lower mounts is the only way to lower without affecting how the piston sits in the damper at static height.
Also, you should NEVER droop spring on front coils. Any coilover will go low enough without drooping. Simply remove collars up front if you want to go lower.
Hope this helps.
I was hungry when answering that question dammit :p.
It was easier for me to adjust the coils exactly how I wanted off the car. Just went by the instructions given when I bought the coils, so they weren't even on the car yet. I am not adjust for preload, I'm doing basically zero preload w/ just enough tension to keep the springs in place.
Adjusting bump stops, meant enough preload on the springs to keep you from hitting bump stops. Sure, you could do it w/ trial and error, but I believe there is some sort of better equipment to help you determine this. Sometimes my fingers don't type all the words I'm thinking, sorry.
Sure, you can adjust preload all you want by yourself... but it won't be much accurate or truly beneficial unless you have corner balance scales. I guess it depends on what you are preloading for... I would adjust preload only to balance the car & keep it to a minimal for maximum suspension travel. "Most" of the time you'll be fine w/ a lil preload, but you don't know for sure how much that is affecting your whole setup.
Of course, I'm probably just talking out of my *** again as usual... sorrrryyyy.
