Lobot wrote:The stock piping for the intake is the same size as the Ingen intake, I found this out when I was looking to buy an Intake, all your paying for there is the crome look, and I looked at dyno that a friend of mine had run on his 240 and with the ingen intake he got 1.5 less horsepower than with factory piping and a K&N cone air filter so I guess you can see a differance in the numbers on the Dyno.
P.S. Venom Intake is pure Crap....
The stock piping IS NOT THE SAME SIZE!!!! how many times do people have to go through this!!? Yes, the ends are the same size, but that is it. The AEM tube is more direct than stock, and it stays the SAME diameter all the way through. The stock plastic pipe gets VERY narrow in the middle, and has MORE RESTRICTIVE passages as a result. Your friend payed to have his car dyno'd before and after an intake install... that sounds suspect... but giving you the benefit of the doubt... if those results are accurate I would say it would have more to do with the filter, than the tube. ALSO... the AEM intake is not chrome.. it is powder/zinchronium coated for heat insulation... something the stock pipe does not provide.... and yes,... the styling is improved also. There is no doubt that the difference is VERY slight... but when you continue building the car... the differences become exponential. You are right to an extent, but your logic is flawed... cutting corners will only get you so far... and if you want to seriously tune your car... hack jobs and jerry rigs will haunt you in the end. But... hey that's up to you.
And it has nothing to do with how "smooth" the pipes are...
