Precut DIY Tint Install
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Has anyone used a precut tint kit on their altima coupe? would you recommend it? How hard was the install?
Colton92
What percentage did yall use? Is it hard to see out?
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
Also see post here: http://forums.altimas.org/zerothread/343958
I purchased a set of pre-cut tint kit. The parts were cut perfectly for my car & the on-line video's & instructions were great.
...however I am a perfectionist. Although the tint was cut exactly for the windows in the car I managed to trap dust between the tint & windows. I tried doing this myself. If I had a helper I'm sure the job would have went smoother. I did an impeccable job of cleaning, but I do not have a garage to work in & the day I did my install it was windy ... So in the end after doing the all windows & trying to live with the tiny trapped dust I just ended up removing the tint.
My advice to you is follow the instructions carefully & clean the windows very well. When you are done cleaning them ... clean it again, double check & clean again.
Good luck.
