Precision Turbo Line
I H8 UR DSM
Introducing Garrett GT Technology
Precision Turbo and Engine brings the new Garrett GT technology into our product line, incorporating the latest advances in boosting technology
New, efficient turbine stages deliver more power to your engine with faster spool up. Improved wheel aerodynamics and a wider range of wheel trims increase efficiency, which improves engine performance.
Precision Turbo and Engine is an authorized GARRETT GT PERFORMANCE DISTRIBUTOR and has access to over 1,800 Garrett components.
If you're looking to add a turbocharger to your vehicle, or need to upgrade an existing one, our experienced staff can answer your questions and provide you with today's latest turbocharger technology to help you exceed your expectations.
Look for the Logo that signifies the latest Garrett GT technology.
***** Introducing our new turbochargers for the Sport Compact market. Precision turbo's are newly designed based on the proven TA34 turbine housing utilizing a hybrid wheelset that feature Precisions new 360° Full Race Bearing System™ for maximum oiling and reliability. These turbochargers utilize a Precision high flow T04E style compressor housing which has been totally redesigned for maximum efficiency. These turbochargers are built with T3/TA34 high flow exhaust housings in .48 and .63 A/R, or T04 Tangential in .58, .68, .81 A/R. They also include CNC matching compressor covers with an anodized aluminum backing plate.
Full Competition Bearing Systems are Standard with our Performance Turbochargers
TO4E Style Compressor Cover, T3/TA34 Turbine Housing
P/N CompressorTrim Map TurbineWheel A/R TurbineTrim Retail SC504869 50 trim T31 .48 69 SC506376 50 trim T31 .63 76 SC324869 54 trim T31 .48 69 SC326376 54 trim T31 .63 76 SC344869 57 trim T31 .48 69 SC346376 57 trim T31 .63 76 SC444869 60 trim T31 .48 69 SC446376 60 trim T31 .63 76 SC604869 60 trim T31 .48 69 SC606376 60 trim T31 .63 76 SC516370 60 trim T350 .63 70 SC526376 60 trim T350 .63 76 SC536369 60 trim T04 .63 69 SC546369 60 trim T04 .63 69SC616370 56 trim T350 .63 69SC616376 56 trim T350 .63 69 SC616369 56 trim T04 .63 69 SC616376 56 trim T04 .63 76
ROLLHARD Performance is now a distributer for Precsion Turbo. As many people here know A Lot of cars on the track recently are swearing by Precision turbo's, and having great results. All the top dyno'ing supras are running Precision turbos. So Precision definitly does have a good reputation, and is used on many 900+whp cars : )
Contact Us or Precision with any questions.
Thanks
Here is their websitehttp://208.55.185.139/
