KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Wed Sep 13, 2006 4:58 pm
The MAF will do it's thing, but you'll likely need some fueling correction while in boost, as the boost AFR will probably need to be lower than the N/A WOT AFR. Yes, 12.5:1 is ideal, but not always perfect for every engine and every setup.
I'd recommend making sure your wideband is handy for the first few testing runs and do some datalogging. That way you can tweak the map where needed.
