Pre Turbo Items
Dlauth
Car: 1995 240sx SE Concord Gray
Im in the process of saving for a turbo kit. I was wondering if there was anything I could get before I got a turbo. Like oil and EGT gauges and maybe an A/f Gauge. Basically I was wanting everything I need for a easy install when I get a kit. Thanks
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
yeah, gauges are good. oil pressure, boost, water, egt or WIDEBAND(not a cheap narrowband afr meter)buy a full 3" exhaust, and a fuel pump. thats basically the only thing u can do pre-turbo
Florida240sx
You can get an enthalpy ecu and your injectors and mafs already in your car. That way only thing you do is unbolt stock and bolt in turbo stuff, no wiring/electronics to deal with.
Craving4Boost
Car: 91 240sx fastback
possibly change out your stock clutch as well.
