fueler wrote:yes, the suspension relies solely on the strut shaft (when fully decompressed) to stay together
set the truck down on the ground on its own weight and that all changes, now its resting on the spring and it'll only rely on the shock shaft if you extend the suspension all the way (jumps) or if you jack your truck up off the ground.
It sounds like youre pretty new to this, i wouldnt try this without a knowledgeable friend around to help.
Extremely new. But it honestly doesn't seem
that difficult. I'm just covering as many bases as possible, before I get down there. I got a friend who has done it a few times I can rely on. I appreciate your concern!
So lets see if I got this down...
1. LOOSEN FRONT WHEEL LUG NUTS.
2. RAISE THE FRONT OF THE VEHICLE.
3. PLACE ON JACK STANDS.
4. REMOVE THE WHEELS.
5. UNCLIP THE BRAKE HOSE FROM THE STRUT BRACKET AND DETACH IT FROM THE BRACKET.
6. REMOVE THE BOLT SUPPORTING THE ABS SPEED SENSOR HARNESS AND UNCLIP THE SENSOR.
7. REMOVE THE NUT AND DETACH THE STABILIZER BAR LINK FROM THE STRUT.*
8. REMOVE STRUT-TO-KNUCKLE NUTS AND KNOCK THE BOLTS OUT WITH A HAMMER AND PUNCH.*
9. SEPARATE THE STRUT FROM THE STEERING KNUCKLE. (BE CAREFUL NOT TO OVEREXTEND THE INNER CV JOINT AND DON’T LET THE KNUCKLE FALL OUTWARD)
10. REMOVE THE THREE STRUT UPPER MOUNTING NUTS (IN ENGINE BAY). SUPPORT STRUT FROM THE BOTTOM WITH AT LEAST ONE HAND BEFORE REMOVING THE LAST NUT.
11. REMOVE STRUT THROUGH THE FENDER WELL.
12. INSTALL SPRING COMPRESSORS ON OPPOSITE ENDS AND ALTERNATELY COMPRESS.
13. WHEN FULLY COMPRESSES REMOVE PISTON ROD NUT AND SPRING SEAT.
14. REMOVE COMPRESSED SPRING AND SLOWLY REMOVE SPRING COMPRESSORS.
15. COMPRESS NEW COIL SPRING AND PLACE ON NEW (OR USED) STRUT.
16. INSTALL SPRING SEAT AND PISTON ROD NUT.
17. SLOWLY REMOVE SPRING COMPRESSORS.
18. RE-INSTALL THROUGH FENDER WELL.
With of course replacing worn parts throughout and tightening to torrque specs. How's that?! Missing anything?
fueler wrote:also - where is your battery tie down?? whats holding the battery in place?
It's just off in those pictures. Funny enough though, I didn't have one for the longest time!
