BRubble »
https://forums.nicoclub.com/brubble-u240123.html
Wed Aug 13, 2014 2:51 pm
I'm thinking along the line's of DR.
Get a Reputable Professional to check the Timeing.
In the mean time,, pour in a bottle of Chevron Techron Injector cleaner and Water remover in the Tank. Injector's can make Crazy Sound's Too.
Is the Engine Useing Any Oil? Did they run a compression Test to see if the Cylinder's were loseing too much pressure?
77K mile's seem's way too early for an Engine Build,, unless it was Abused in OffRoad Activitie's. Was the Truck Abused in Rock Climbing, Mudd Playing, Water Crossing Above the Axle's, or High RPM Full Throttle in Lower Gear's, which can cause severe damage to Top end and Engine.
When they said Engine Rebuild,, maybe they meant Top End. The Valve Train,, can also make or Cause Racket, if way out of Adjustment or Damaged.
