pre cat gone bad
TurboSilvia7587
where can i go get a pre cat for cheap because mine is messed up and it makes a lot of noise after 3000 rpm. any suggestions, thanks in advance
onosqv
Car: '92 240sx Vert
Makes a lot of noise like rattling?
If it's just rattling, you can probably get away w/ removing the heatshield around it. If you are paranoid you may start a fire, take the heat shield off and get some exhuast wrap or something to replace it or see if the bolts are loose or whatnot.
TurboSilvia7587
yup, do u know where i can get one?
onosqv
Car: '92 240sx Vert
TurboSilvia7587 wrote:yup, do u know where i can get one?
exhaust wrap? heatshield?
Well, exhaust wrap, either ebay (get the higher rating ones, I think like 1500 F or something), or from one of our sponsors, I forgot who sold these, but one of them do. Just do a search for exhaust wrap.
As for the heatshield, only way to get that is from one of the sponsors/dealer in the advertiser's section. This problem has been covered a lot, you should Search, really - you are just using the wrong terms -> change "pre cat gone bad" to "exhaust rattling" or something like that.
