Pre Bose Amp Wire Colors
KingOfBattle
Car: 2008 M45x
I have done my best to find out what wires correspond to what speakers on the 14 speaker Bose amp. I want to use the signal before it goes through the Bose amp so it is a "clean" signal.
Has anyone done this? How have you added amps to your M and where did you make the connections? Are the wire colors different for an M that has the Mobile Entertainment System??
:confused:
--2008 M45x
mexillis
Car: M45s
You're going to have to look in the fsm, that's where I found all the wire schematics for my 06
KingOfBattle
Car: 2008 M45x
Does the FSM have "pin-out" diagrams or the actual colors?
Thanks
Minus (-)
Car: 08 M35x
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
I went this route when I initially started my upgrade but on my 06 the output from the factory hu was all over the place. The Bose amp does a lot of processing to the signals apparently. The way I got it to work (as well as most if not all others) is to use an LOC on the speaker output from the Bose amp to the new amp(s). This has worked very well for me and I have all but the factory sub externally amp'd now. The level on the rear deck speakers, the seat speakers and the center speaker is not as high (contained to 20 watts) as I have not replaced them with aftermarket yet.
KingOfBattle
Car: 2008 M45x
Thanks for your help and recommendations.
