chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Wed Aug 24, 2005 1:45 pm
what? that makes no sense. you cant just stack washers on somthing to adjust camber. well, i suppose you could put washers on the actual top mount studs, but that is ghetto and dangerous, and ive never heard of anyone doing that. also, you cannot put a washer from an eccentric bolt onto a regular bolt. if you have an 89/90 it comes with a single eccentric bolt in the shock mount, if you have a 91-98 the camber is set from the factory and must be dealt with in other ways (redrilled shock bracket, camber plates, aftermarket eccentric bolts, etc)
