tedthayer »
https://forums.nicoclub.com/tedthayer-u317412.html
Sat Jul 11, 2026 4:43 pm
Nissan M6 Transmission Cooler ("Beehive")
I'm stuck, need some information ...
The pre-2013 Nissan Sentra CVT Transmission has a history of over-heating when climbing hills in the desert southwest in the Summer. There is an after-market kit for post-2012 CVT equipped Sentras that replaces the Beehive with a version that sends the transmission fluid through an add-on external radiator. Apparently, it works, but before I change mine, I need to understand how the Beehive works.
Here's what I know:
Engine water from the radiator is sent through the Beehive to keep the transmission warm ... not cool. Whatever the radiator coolant temperature is, that's what the transmission fluid/oil is warmed up to. In the southwest deserts when it's over 90 degrees or so, the transmission wants to overheat under high-speed loads. If it gets too hot, because the radiator coolant isn't dissipating the added heat, the ECU will put the vehicle in "Limp Mode" in which engine speed may be limited to 2,000 rpm and highway speed to 45 mph or less. It's not a bad feature if you can get to a place where you and the car can chill for a while! Adding an aftermarket "Beehive" CVT Transmission Cooler is probably a good idea ... I'm told that it works! As long as there is no adapter required.
What I don't know:
The Beehive is very tightly bolted to a mounting flange in the transmission with a 3-1/2 inch O-ring holding the surface a tiny fraction of an inch away from the transmission fluid/oil in/out port and filter mechanism. on the Beehive plate are two 1/2 inch hols that allow the fluid to flow into the Beehive separate from the engine coolant. I don't understand what creates the pressure gradient that causes the fluid to detour through the Beehive. Two identical holes on a flat surface has both the incoming and outgoing fluid in essentially the same plane. The only thing impeding the flow is the filter, but its outer surface and the plate containing the Beehive holes are effectively on the same plane, and one would think at roughly equal pressures because the plate is all that secures the filter in its housing..
The challenge:
To mount the after-market Beehive cooler (which has two pipes for engine coolant and two separate pipes for transmission fluid) requires an adapter, which I'll have to fabricate so differing mounting bolt configurations can be accommodated along with an appendage to hold the filter in place. The adapter will be made of strong 1/4-inch steel that will use the same O-ring configuration as the Beehive to seal it to the transmission. The after-market unit will mount the very same way (compressed O-ring) with a slightly different bolt configuration). I'm not confident that an additional quarter-inch of space between the Beehive mounting plate and the transmission will "go with the flow!"
Worst-comes-to-worst, I can modify the after-market Beehive to fit directly ... but THAT would be a BIG deal - and expensive! Is there some sort of internal mechanism in the Beehive that pumps the transmission fluid through it? Or What?
Now you know the rest of the story - or NOT!
