Pranking My Buds Civic
Post all your Nissan electronics, car audio and stereo questions here!
UnderPressure
okay to all the wiring gurus. . . .im trying to wire the signal to the horl in a 98 civic coupe.
i have a t-tap hooked to the signal wire, on a wire that is t-tapped into the horn lead. its not working! why not?
scruf1986
Car: the car
First off I would like to compliment your signiture. Second off why is the horn lead t-tapped. That may be why its not working. Try crimping the signal on the horn lead.
UnderPressure
1) want to keep all wires intact. 2) want to keep the horn functional.i was hoping that when he hits the horn the light will come on, and when the light (signal) lights up it will honk the horn too. thatd be funny as hell. any suggestions?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
that takes cutting and splicing...
you can do something like tapping the power wire from something under the hood (blinkers...) and tap it over to the power on the horn...top right corner if ur facing the windshield if i'm not mistaken...very easy...tuck it away and it'll take him a while to notice...
(oops it's not a 240sx...forget i said anything about placement)
Holisticbeatz
What a friend you are...
UnderPressure
mainevent. thats what i did, and still nothin. i think maybe the t-taps arent penetrating the wire sheaths? any other possibilities.? thanks guys for you help
MainEvent212
no i think you have to type a ground at some point in there...
UnderPressure
shouldnt it go thru the resistor (horn/light) and then ground at that point?
