I couldn't get any of the suspension member bolts off today. None.I could barely get to some of the nuts, even with a standard wrench kit. Even those I did get to would not budge a bit with the air impact wrench.
So, I'm resorting to plan B, which is composed of the following two steps: - Learn more about how these air impact wrenches generate torque - Pick up a larger set of wrenches, impact sockets, breaker bars, etc.
To determine the torque that the existing air impact wrench can garner, I found Universal Tool company on the web at:
http://www.utsupply.com/viewpr...=2032
Apparently their UT-2210 air impact wrench is no longer sold, but, I was able to find a used Universal Tools UT-2210 wrenches for sale (see photo)on ebay (although I never did find a set of good pecifications):
http://cgi.ebay.com/ebaymotors...34787
The nearest UT part seems to be UT-2147P (I'm guessing), having specs of: - "Limited Use" (designed only for the home & hobby, not commercial) - 1/2 inch Impact Wrench - Dynapact® clutch for high torque output - 8,500 RPM, 425 ft. lbs., 7-1/2", 6-1/2 lbs., $108.67
If mine did generate 425# (in reverse), it still wouldn't budge any of the 1990 Q45 front engine crossbar bolts holding it to the frame. -
http://www.nicoclub.com/zerothread?id=77266 - ("
www.nicoclub.com/zerothread?id=77266")
But, I suspect it did not generate anywhere near that amount of torque,so, that's why I'm looking to better understand the mechanics here.
I still don't know how to determine if it's actually generating 425 pounds, but, I learned (from the web) that SAE 30 extreme pressure oil should be used in the gun (about an ounce should be poured in an oil hole on theside somewhere). Also, after each use, that 30 weight EP oil should be addedto the air inlet and the gun should then be spun before storing. Since the previous owner of the air impact driver left us years ago (according to his wife), the UT-2210 air gun probably hasn't had oil for at least as long.
Also, about 16 oz of that 30 weight oil should also be placed in the air compressor (not the multi-weight 10W30 I put in there previously) as the multi-viscosity motor oil additives apparently carbonize inside the air compressure cylinders.
So it was my bad both for running the air compressor on 10W30and for running the air impact tool without oiling it (if I only knew then what I now know). Maybe (just maybe) that's why my setup won't generateanywhere near enough torque to remove Q45 front engine crossmember nuts.
I also learned that the 4 settings do regulate the air pressure at the baseof the air impact wrench. My problem (since there are no markings on the gun - they probably were on a sticker somewhere that's not there now) is how to determine if it's on #1 or #4.
After looking at other guns at Sears, I will assume the number on the dial which is closest to the air inlet is the actual number (#4 beingthe higher air pressure and #1 being the lowest).
I also picked up a set of impact sockets (not cheap), impact extension rods, and a wierd-looking 360 degree impact universal joint (which looks like a stick in a round tub instead of looking like a U-joint). Just to be safe, in casethe air impact tools continue to fail me, I picked up three lengths of pipe and two different kinds of breaker bars.
I'm hoping that at least one of these methods will break those nuts loose!
