ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sun Dec 19, 2010 8:42 am
Without being there it is difficult to diagnose. Before pulling anything apart, on a cold start depress the gas peddle and see if the same happens.
When warm it has this problem, so when warm there may be too little fuel, the enrichener circuit is not needed. What shape is the EGR circuit, if carboned up...problems
Is battery voltage and alternator good, low voltage will do this also.
When it slows down does it stop when problem exists?
Try removing the air filter put everything back with no air filter and test out.
Fuel, air and spark at the right time...
