evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Dec 14, 2008 5:54 pm
silvertwin definitely knows these cars better than I do, but generally when a car as run in it's because it's getting voltage when it's not supposed to, the most common part failure to causet his in most cars is the voltage regulator, which on the Z32 is internal to the alternator, if you find nothing at the pump, it might be worth disconnecting the alternaotr and sssing if the problem still persists with the alt disconnected, the car and be started and run for a while on battery alone, long enough to see if the run on continues should be no problem at all
