Only thing I could find is the bleeder screw itself, with the cap:Malbec 56 Beast wrote:Does anyone have a party number for the rubber cap on the bleeder, can't find one specific to the sport caliper, Any help will be associated.
Andy
Have you had your timing chains replaced under the recall? The reason I ask is that all of the powertrain fluids are replaced when this job is done. Last year, I had all of my fluids changed just like you did...then later on down the road, my car threw a P0024 exhaust valve timing control code. I was able to limp to the dealership, and had the chains replaced. So, all of the money I spent went down the drain.Malbec 56 Beast wrote:So,
I got everything done but the trans. I didn't order the correct fluid for it. It requires 8.7 qts I think but I only had 2 qts. I got the ATL and the ATF (Amsoil) fluids mixed up and my contact for Amsoil is out of town.
They did both diffs and the transfer case plus front and rear rotors & pads done. I applied all the fluids and parts so it was a labor only. I was charged $75 for all the fluids to be changed and $80 for all pads and rotors to get replace.
I thought it was a great deal.
Andy
List of fluids (bottom of first page)...just the front diff, not the rear. I guess doing the AWD requires more work than the RWD.Malbec 56 Beast wrote:Ya the timing chains were done in 2015 but I like to put Amsoil in, having said that it looked as though it was required again by the look of the fluids.
Why would they do all the fluids at that point? Maybe in the motor but why would they do the diffs etc. It didn't look fresh to me. That's a good to know though. I have a leak which looks like it's coming from the covers, they put some dye in the oil to see where it's coming from.
Ya I saw that number after I asked I was hoping to find them locally. The dealer again lol
