defrag010 »
https://forums.nicoclub.com/defrag010-u35865.html
Mon Jan 16, 2006 5:50 pm
http://www.powertraincontrolso....html
It says that it supports our RE4R03A transmissions, but I'm wondering what all is needed to wire it in?
How does the TCU communicate with the ECU, and what information is shared inbetween each other?
I'm willing to bet that the transmission is controlled like any other electronic one - it uses the TPS, map, kickdown switch, and maybe a few more small switches.
Will the engine ECU work fine with the TCU unplugged, so you can run the PCS transmission controller as a standalone? Will it just throw a CEL for the abesnse of TCU communication?
