Powersteering problem
Brandmeister
Car: 1989 240sx Hatch, 2000 2nd gen. Miata MX5
I have a 1989 240sx with a KA24de dohc motor swapped into it. Shortly after the engine swap from sohc to dohc the power steering pump began to go out and it locked up after the power steering fluid turned black. Now I am on my 4th pump and the same thing is happening again. Any ideas what is causing my pumps to lock up? Any information would be appreciated.
Goldeneagle
Car: 1992 240sx Coupe
What fluid are you using?
You should be using automatic transmission fluid, rather than standard off the shelf power steering fluid.
