Powerslot rotors, anyone else have a problem?
7anshin8r
Car: 96 Nissan 240sx
SO now the next big annoyance... The guy who is putting my car back together for me can't get the powerslot rotors to work. He can get them on, they turn fine, then he puts the wheel on and no more turning... Enjuku is confused as to why... So am I, they are the correct rotors. The mechanic says the offset of the rotors is wrong, grrrrrrrrrrrrr... Has anyone else had problems with the powerslot rotors?
P.S.
I did drive up to see the car on the rack, I wanted to see what the problem was. He had one front rotor stock, no wiggles and the tire worked fine (turned) once put on. On the other side he had the powerslot rotor on, it wiggled side to side a little while on, and after the tire was sat on the lugs it would not turn at all. The mechanic insists that the offset is wrong...
*EDIT*
Sorry, i'm used to posting on the other forum. My car is a 1996 Nissan 240sx (s14) base model 4 lug with no ABS. Hope that helps some.
Modified by 7anshin8r at 8:12 AM 7/23/2008
Crazyirish
Car: Nothing noteworthy at the moment...
You got the wrong rotors. The box might say they are the right ones, but they are obviously not.
7anshin8r
Crazyirish wrote:You got the wrong rotors. The box might say they are the right ones, but they are obviously not.
You are correct. Enjuku says they changed the brake setup part way through the year on the '96 so I am sending them back for the correct ones.
