PowerLab GT35R Single Turbo Kit Release!!!/Intensepower.com
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
IntensePower.com
Car: Widebody Z33, Veilside Fortune G35, 1400 WHP Supra JZA80, S14 SR, S14 RB25, S14 RB26, S13 SR
PowerLab GT35R Single Turbo Kit 350Z 03-06
The PowerLab GT35R Single Turbo Kit consists of only the highest grade quality parts and materials offered on the market including Garrett, TiAL, TurboXS and Walbro.
Benefits of using the Garrett Ball Bearing GT series turbo is increased efficiency and spool up time as well as reliability by using water cooled methods. Other Benefits include the largest fuel injectors offered of any turbo kit on the market in the form of 550cc injectors and a Walbro 255LPH Fuel pump for optimum fuel delivery. Stainless Braided oil feed lines for ultimate aesthetic and reliability purposes along with high quality custom extended A/C line, C&C Oil Pan Spacer, mandrel bent and tig welded Piping components as well as one of the largest intercooler cores offered on the market with minimal modifications needed to retain the factory crash bar.
PowerLab is one of the only companies to include TiAL Wastegates and Blow Off Valves as standard issued components in all of their turbo kits. A 50mm BOV and 44mm External Wastegate are used in the PowerLab turbo kit for their proven history of excellence and performance on forced induction applications.
PowerLab doesn’t stop at fuel delivery and quality hard components as they have decided to include a TurboXS Map Sensor and TurboXS Utec Engine Management system complete with base map.
The GT35R Turbo Kit from PowerLab offers the most efficient and highest horsepower potential capabilities on the market. Whether you’re looking for approximately 400RWHP on a stock motor or 653RWHP on a semi built motor and upgraded fuel components, then the PowerLab GT35R Turbo Kit is the kit for you.
Turbo Kit Features:
- Garrett GT35R Dual Ball Bearing Turbo with .82 A/R Turbine
- TiAL 44mm External Wastegate (Silver Top)
- TiAL 50mm Blow-off Valve (Silver Top)
- 27"x12"x4" Front Mount Intercooler
- Polished Stainless Steel Exhaust Piping with 3" Downpipe
- Polished Aluminum Intercooler Piping
- Billet Aluminum High Capacity Oil Pan Spacer
- New Custom Extended A/C Line
- Stainless Braided Oil Feed and Return Lines
- All Necessary Hardware and Installation Instructions
- 550cc (Set of 6) Injectors
- TurboXS Engine Management Unit
- TurboXS MAP Sensor
- Walbro 255LPH Fuel Pump
- Currently tested on Manual Transmission Cars Only
- Approximately 15 hour install time
Taking orders now!!!
Purchase link ----> http://intensepower.com/pogttukit350.html.
IntensePower.com
Thank you for the great response and orders through out the Nissan community!
Return to “Advertisers' Marketplace!”
