PowerFC D-Jetro Install Question...
crzykrackr
Car: 1991 240sx
I was wondering if anyone has installed one on their SR? Is the MAP replacement pretty straight forward? Just some heads up on what I will need would be appreciated. Thanks.
Gspec
Car: SR swapped 1991 240sx coupe
nothing to it...you simple have to find a vacume source after the Throttle Body, and connect a vacume line from it to the map sensor.
The iat goes on the cold side of the charge pipes, and it doesnt matter which way its wired to the ecu, it'll read the same both ways.
nwmrkt
Car: S13
how about the apexi super suction intake? I believe its available with a d-jetro option...meaning it has all the source plugs and what not.
