I've got a late model kouki sr20det running a power fc (414AN016).The boost control kit I have is (415A013) which is compatible with my pfc.
1. I need to know if all components are installed correctly.2. How to wire solenoid to stock harness.3. Can I wire directly to pins on ecu? Which ones?
Thanks
I tried following this diagram:
Solenoid is mounted here, with vaccum line to wastegate actuator.
MAP sensor is mounted here and plumbed to Nismo FPR.
I figured out that this normally plugs into the stock solenoid plug. Apparently the stock boost solenoid was removed and so was the connector. Solenoid plug
