Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Wed Jul 20, 2005 10:22 am
I don't know of any alt that will just drop right in, but I suspect a late model GTR alt will and should have plenty of juice for you due to the GTRs have all of those nifty electronic systems like traction control, HICAS, automatic climate control, etc. in addition to all power accessories.
If you are willing to make a spacer (or possibly 2 spacers) almost any alt should fit. I've got a 2004 Acura alt rated at 130A that looks like it might fit with a new bottom spacer (and of course swapping the pulley). It is a rather small frame for 130A.
However, as Nick said, your engine typically would not die because of low current from the alt. You might see your headlamps go dim, but I have never heard of an engine dying (at least not right away). So make sure you check that IAC before trying to fit a larger alt.
