AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Fri Mar 13, 2009 7:56 am
What site are you looking at? Check out amp guts and they show max current draw for that amp at 114A, which is below the max listed here (though I use that site as a reference only). You'll be ok with 4 AWG for now, but if you upgrade anything later, you may require more. Also, your voltage shouldn't drop much if your alt can keep up (which it probably can't - it would be able to if the amp was the ONLY thing drawing power, but it obviously isn't) and you've upgraded the big three.
As far as speaker cables go, you'd be fine with 12 AWG (it's a bit easier to find than 10). You're not really pushing enough power to require much more than that.
Thickness of the RCA cables doesn't matter much (realistically at all) because the signal is at such a low voltage and current.
For fuses, you want to fuse for the wire's rating (not the equipment). The amp has its own fuses. You should fuse something like this:
0 AWG - 300 amp2 AWG - 200 amp4 AWG - 150 amp8 AWG - 75 amp
(anything smaller than this is a terrible idea to run for mobile A/V)
Finally, don't get a cap. Pretty much worthless. All it will do is increase draw on your system and kill your battery and alternator a bit quicker. I would recommend an upgraded battery, but that's about it. Before a cap I would always take an extra battery (but for your current setup this would be total overkill).
