dc1984 »
https://forums.nicoclub.com/dc1984-u34446.html
Sun Mar 08, 2009 10:52 am
i know when my driver side window wasnt working, i could hear it making a click inside my door panel when i tried to use it. so i took off the door panel and there is a box little electrical box that a wire harness clip from the power windows control goes into. i took that out and went to the junk yard, found some old random nissan car with power windows, ripped off the door panel and it was the same part number, put it in and it worked likea champ. only cost a couple bucks too. then again it might also be the motor. as for the guy with both not working( im assuming since u pluralized "windows not working") it is probably fuse or something. check all the connections. maybe somethin just came unplugged.
