I can't seem to reach the screws. Any other method? This was the reason why I thought you need to have the windows rolled down.fourdrinie wrote:Try taking the door apart...and see if you can reach the two bolts that attach the regulator to the window. If you can take those two bolts off, push the window aside and continue removing the regulator and motor.
Thanx. This is mostly what I'm using as a guide. The FSM isn't helpful at all.yodawill2000 wrote:good how too on http://www.fuzzycats.comgo to the J30 DIY page.Simple job . Did mine in 15 minutes.
