SWIFT_DRIFT »
https://forums.nicoclub.com/swift-drift-u892.html
Tue Jul 08, 2003 4:00 pm
You would need to splice/run both the power and the ground wires from that switch to the passenger side window main motor for that to work. However in doing this I'm not sure if the passenger controls would still operate normally. I say this because the passenger side switch/current would always be in the closed position. So unless you ran the power from the driver window (as it's going down auto function) to the passenger side, is the only way it would work, I think. :P
