raxx »
https://forums.nicoclub.com/raxx-u29469.html
Tue Oct 11, 2005 5:12 pm
Anyways I figured what the problem was.....well kinda of.
The problem was from under the center console. There is 2 things that plugs up. The wires/plug that runs from the driver side to the center console (I guess it's the main power plug, not sure). And the other one wires/plug runs along the passenger side to the center console, and the power switch for the back window is wired up to that too.
Anyways, I so happen to unplug both the plugs. Well after that only the front windows work. I plugged it back up and it stopped working again.
So I'm guessin I have a shortage or something that has to do with the other plug, which I think connects and has something to do with the top, because you know when you let the top down, the back windows goes down also. Yet I don't know where to begin to find the problem, so I took a short cut and just rigged it up the wires myself.
I left the wires/plug from the passenger side off, and cut the plug off the driver side, and cutted the back window wires also.
I just connected them from color to color and it worked. Which of course now, the back windows doesn't roll down as the top goes down. Hopefully it doesn't damage my back windows one day, if I ever forget to roll the back windows before I let the top down.
Thanks for the help though. If you have any ideas on how to fix the problem the right way, feel free to tell me how.
Raxx
