Power Windows Fuse?!
cccp
Car: 2004 Infiniti G35 6MT
howdy gangstas
Driver side window wont go down in my 2004 G coupewondering if theres a fuse for the motor
or should i be looking for a new motor
thanks!
telcoman
cccp wrote:howdy gangstas
thanks!
Welcome to NICO
If all the other windows work, I doubt that is is a fuze but I could be wrong? You will need to find the shop manual and look at the electrical wiring diagram. You could also have the dealer check it if you are still under warranty.
Telcoman
infinititech1
what does it do?? when u push the button does it sound like its trying to run or what?
cccp
driver side stuck closed
passengers side works fineboth buttons light up
if i use the key or the remote key buttons (to open both windows)passenger window opens/closes fineso its not the switchand no any kind of motor soundsalso i didnt find any fuses for em
thanks for the replys
hiryux
Car: 2004 Infiniti G35 Coupe
I had the same problem with my 04 g35 coupe the other day except the windows wouldnt roll up. I had the exact same issue where the passenger worked fine but the driver didnt. I took it to the dealer and they found out it was window lift motor. Hope this helps.
