power window
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Eddiearms
Car: '08 Armada SL
First timer, could not locate Armada ('08) forum so I'll try here. Power window won't close, no previous problems. Looked at fuse box, none listed for windows. Read elsewhere the possibility of CB's for individual windows but can't locate, manual no help. Would appreciate any info. Thanks for your time. Ed
mdmellott
Car: '13 Kia Soul+ 2.0L AT
The first ones built were called Nissan Pathfinder Armada. Now it's just Armada. Definitely an outstanding, stand alone, full size SUV. Sometimes the administrators of NICOclub will catch a post like this and transfer it to the correct forum. The Pathfinder forum in this case, even though their built on a Titan frame.
Are you asking about one window only that won't close? If so, it could the the regulator motor or a gummed up regulator track but I don't want to get ahead of myself. Are there any other symptoms or does it just seem to be dead? Any type of sounds at all when you push or lift the window toggle switch? Did it just suddenly stop working or was the window acting sluggish going up or down when it was previously working?
Eddiearms
Car: '08 Armada SL
Thanks for that info. One window ( fr. pass.) No previous problems, lowered all the way, 10 secs. later tried to close and got nothing. No sounds at all when attempting to close. Seems like it's "dead".
mdmellott
The best way to deal with this is to first diagnose the issue starting with the passenger side diagnosis procedure outlined in the 2008 Armada Nissan Factory Service Manual Section PWC (Power Window Control System) https://www.nicoclub.com/service-manual ... 08/pwc.pdf However, to effectively navigate service manual sections, you need to create a folder on you computer and download the manual to that folder, one section at a time. Every line in the Contents page of every manual section is a link to the described subsection within the body of that manual section, for quick navigation to a specific page. You will see other manual sections referenced, highlighted in green as a link to that manual section, but it cannot be accessed while navigating a different section online. It's best to download the entire manual, one section at a time, to your computer so that you have complete navigation access to all the necessary manual sections in order to effectively go through the diagnostic procedures and pin point the issue you are having.
This may seem like a hassle, just to download all these documents when most of them are not applicable to your current issue, but it's worth the time to do it because it will save you time in the long run for your current issue as well as other issues in the future. Electrical issues are usually very easy to fix but sometimes difficult to diagnose without the right information to reference. Nissan did a fair job with this service manual for the service technicians to use. I know you will find it helpful. You don't want to start throwing money at parts in hopes that will fix everything. You might get lucky doing that but you might not. Good luck with all this.
fyi - The NICOclub administrator did copy your post to a different forum. It's still in the Nissan Trucks forum where you posted it and it is also in the Infinity QX56 forum as well. Clicking on the QX56 link under Infinity Forums you will see the forum is called Armada Forum/QX56 Forum/QX80 Forum. They should have added an Armada link under the Nissan Forums, like they did with Pathfinder and QX4, combining both forums into one since they are essentially the same vehicle.
Eddiearms
Car: '08 Armada SL
Thanks so much for your time and effort.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
