power window
I_eat_hondas
Car: my car and my new baby boy Caleb
the drivers side window only works when it wants to. which is not very often any guesses?
b240
The window regulator is probally going out , or theres a short in the wiring. Have you taken apart your door panel to check it out?
bj180sx
Car: cars
yes, clean it with contact cleaner and make sure the connections aren't corroded. Also check the wires in the door jam and make sure none are broke,
I_eat_hondas
fixed, it was a bad relay between the switch and the motor
mark
my power windows stopped working on 3 different ocassions. first it was the switch, then it was the window motor, then it was the amplifier. I changed all 3 and its been working fine now for about a year
S13Owner
I_eat_hondas: How much did it cost to replace the relay?
I_eat_hondas
didnt cost me anything, freebie from a junk yard
S13Owner
thanks for the info. I'll look into that
1991240xs
what about windows that just are starting to go real slow?...my drivers side window is atleast twice as fast as my passenger side~
I_eat_hondas
Mine do that too incold weather, but its really frickin cold up here too. like less than 30 everyday. mine **** the bed again. I think it may be the plug that comes from the switch to the relay. what a pain in the ***!!! Anyone have a FSM and can tell me what to do about a code 21? any help would be great, I just got an FSM and it has not arrived yet!!
b240
1991240xs wrote:what about windows that just are starting to go real slow?...my drivers side window is atleast twice as fast as my passenger side~
same here..heh
