Power Window Problems
bigG
Car: 1993 Nissan 240SX LE Convertible
None of my windows work. When the car is on, I get a click every eight seconds on the breaker and a buzz somewhere in the engine bay, sort of near the transmission (I don't have a lift, and I can't quite tell where it's coming from). Any ideas? Could it be my ignition switch?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
you check your fuse?
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
Sounds to me like a faulty relay.
Check your fuses, then check your relays.
bigG
I have power @ the fuse, and the main switch. Every eight seconds, I hear a click under the dash (it's the circuit breaker - it stopped when I pulled it), plus a buzz in the engine bay area. The buzz happens right before the click. I haven't been able to track down where exactly the buzz is coming from, but I'm going to take it to a mechanic if I can't figure it out soon. The car's for sale.
Oddly enough, it has fun flawlessly for its entire 99,000-mile life, and he day after I posted it on cars.com, this crap happens. I guess the odds of Murphy's Law happening have been stacking up against me for a while.
Modified by bigG at 4:40 PM 1/21/2008
-RJ-
bigG wrote:I have power @ the fuse, and the main switch. Every eight seconds, I hear a click under the dash (it's the circuit breaker - it stopped when I pulled it), plus a buzz in the engine bay area. The buzz happens right before the click. I haven't been able to track down where exactly the buzz is coming from, but I'm going to take it to a mechanic if I can't figure it out soon. The car's for sale.
or the car just doesnt want you to sell it
nlongitudlatitud
just checking to see if you ever found the problem. i have the same problem. clicking every 8 secs, n the windows dont work
Bryant0086
Car: 1989 Nissan pickup 2004 Nissan Quest SE 1992 240SX vert
There is a good chance one of your window switches is stuck. It may not be stuck mechanically, but it still could be electrically.
I want you to try this :
Hold the window "down" buttons one at a time while you turn the car on. Do this with the quarter windows as well. If you get the same problem, then I suggest you get a repair book with the electrical schematic in it. It is possible that there is another device on the same circuit as the power windows as well.
Bryant
nlongitudlatitud
i tried holding down the window button. doesnt do anything. checked all the fuses n relays. motors fine. tried switching out amp. still no good. the car just keep blinking out every 7-8 sec.(all the lights blink, including headlight n taillights) thinking it might be ignition relay? appreciate any help i can get.
nlongitudlatitud
running out of ideas.. can anybody help???
S15nS13vert
Car: 95 240sx with a s15 engine 6speed transmission, 94 S13.4 SKYLINE VERT and a 08 Lexus RX350
since you have that problem, i will give you 100 for your vert
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
My Car just started to do this as well. Any updates for fixes forr this problem? Need help i work 3rd and its my daily driver, so i dive at night. Thanks
LingeringSuicide
Changed the window relay and the lights quit blinking. The windows however still dont work. Any thoughts?
LingeringSuicide
Since there was no help for me on this topic i had taken the time to fix my problem. If you have this problem you have a short somewhere. My short was under the drivers seat where the wire harness was near the seat rail, Got to close and wore through the white and black wire. Repaired and relocated the wire harness so i wont have that problem next time.
So all in all thanks for the help
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
lol it's christine best keep her
nlongitudlatitud
haha, yea mine was the same problem. just a a open circuit, the blinking every 8 sec is from the circuit breaker trying to reset itself. mine was located under the center consel. melted wires
