S14KoukiMonster »
https://forums.nicoclub.com/s14koukimonster-u36640.html
Tue Jan 31, 2006 11:14 am
I assume since you refer to the motor the're power windows? Take off your door panel again, but this time take a razor and remove the plastic by sliding the blade betweem the door and plastic, slicing through the adhesive goop. Try re-lubricating the track first, and then watch the track move. Several things could be wrong since that probably didn't solve your problem. Make sure everything is snugged and not loose. Check for bent tracks, check door glass sub-channel adjustment( bracket that holds glass), check for stripped gear, check to make sure the motor piece that DRIVES the gear isn't broken because the motor will be powered and working still but unable to engage track movement(problem on Honda's). Check for binding in vertical tracks, seals, ect.............
