rover3l »
https://forums.nicoclub.com/rover3l-u10518.html
Mon Aug 31, 2009 2:27 pm
Thank you for your help and advice
I have solved the problem, well almost.
Following your instructions, I removed the regulator and motor. The channel was clean but there was very little grease left. I cleaned it all out and re-greased it with lithium based grease. Before refitting it, I operated the motor via the door switch and everything moved smoothly and quickly. However, I realized that this was not a perfect test without the weight of the window glass.
I then refitted the assembly and before fully tightening the bolts, I checked the operation again but now with the window glass attached. I actually compared the speed at which the window traveled upwards compared to the passenger side and they were now equal.
Finally I tightened all the bolts fully and then rechecked the operation before re-fitting the door panel. This time the rate of travel was slower than the passenger side but still very much improved compared to before the re-greasing effort.
Next steps will be to see if there is any adjustment in the alignment of the regulator or window guides which could affect how easily the glass moves.
