power window problem : (
Dairus
Car: Nissan 240SX
Hello I give a search before posting here but I saw must of the people that the power window doesn’t make anything. In my case the driver window when you press the button (down) he get down normal but when you are trying to get him up sometimes he start getting up normal but then he stops while I still hearing the motor. Other times he doesn’t get up but when I press the button I hear the motor trying to get him up. This is getting me mad because I got to remove the panel from the door because he gets stuck. I call Nissan original parts and the motor cost 300$ and the regulator cost 230$ and buying in it from a Junker it’s like a box of surprises. Also I don’t know what can be.
cdlong
Car: '95 240sx
try connecting a 12 volt source directly to the motor. there's a two wire plug right before it goes inside the door you can use, one + the other -. one way is up, reverse it for down. if it works reliably that way, the motor is fine. if not, it's bad.
Dairus
Car: Nissan 240SX
Ok I will try it as soon as I do ill let you know what happened
Thanks man
Dairus
Car: Nissan 240SX
Man I did it but he still doing the same that means that the motor is bad : (
Thanks
eejjkk2003
Car: 91' Nissan 240SX SE
Its the Power window Amplifier.....I'll bet $10 on it. Happened to me. Call a salvage yard and buy one for $25
