Power Window Problem Help
John_C
Car: 2004 Maxima
The driver side power window on my '04 Maxima has finally decided to stop working - and the window is currently in the full open position! Initially, the motor was "sluggish" and I could "help" the window raise if I lifted or pushed up on the glass. Occasionally would seem "stuck" in the full closed position, but eventually would break free of the seal and open.
Now nothing - it doesn't appear that the switch is even attempting to operate the motor.
I have removed the driver side door switch module and all of the interior trim panels, but I cannot see that there is even an access hole to get a hand on the glass and see if it can be moved by hand. I've located both the switch module and window motor parts on line... and they are NOT CHEAP!!! And I'm not even certain if it is the switch or motor at this point - although I suspect it's the motor based on the progression of the problem.
Can anyone give me some direction on whether this is a project for a novice DYI'er to attempt, or is a trip to the dealership necessary? If dealership, any ideas on how expensive a fix this is going to be?
Thanks in advance for any advice.
John_C
Car: 2004 Maxima
Anyone?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
remove drivers side window switch and plug in on drivers side to operate the drivers side window
If it doesnt work its probably the motor
Putting a new motor in isnt difficult but you need to carefully organize your
parts to put the door molding back right or it might rattle
John_C
Car: 2004 Maxima
Do you mean to plug the driver's side switch (4-way) into the passenger door switch, or vice versa?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Please refer to the link below, starting on GW-19 for the Power Window System.
http://www.nicoclub.com/FSM/maxima/2004/GW.pdf
ericdiaz
Car: Honda City
Recently starting car, driver side window failed to operate, but passenger front did. Fortunately, passenger side went back up as it was raining.
NutriaforBreakfast
Sorry for the confusion-yes do the above
