vjharpe »
https://forums.nicoclub.com/vjharpe-u1742.html
Sat Jun 14, 2003 5:46 pm
I checked the relay with a voltmeter and it was good -by undoing the connector between the relay and the motor (only a 2 wire connector). When I reconnectedlo and behold the window worked again! The doorwas replaced after an accident, and the wiring futzed up, so I cleaned it up about 6 months ago.I tried to strain relieve the connector this time - hopeit continues to work.
Thanks for the advice (but it would be a bugger toget the motor out of the door!)
