power window out in 92q
bigreese
whats up guys
i have searched the forums and have not found a solution. heres the problem. my driver front window went down this morning and will not go back up. i don't hear a moter sound when trying to raise it. is there a manual way to raise it, as its about ro rain. also, does the door panel just pull off?
jtesensky
Vendor
Car: 2005 Infiniti QX56
2002 Infiniti QX4
Probably your motor, $218.19. Most door panels have clips around the bottom, those pop & release the panel then you lift up. The top portion of the door panel will "curl" over the top edge of the door shell. Make sure you get ALL of the screws off the panel first, there are some screws that attach the panel around the grab handle area...
3rd Q
The armrest is removed by sliding it backwards while pulling gently upwards. Use an upholstery tool or blunt screwdriver wrapped in tape at the front edge to help it release.
Do not try to pry it straight up or you'll break the tabs.
Paul
