MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Tue Sep 23, 2008 2:56 am
My windows all work fine, but the driver window (I never sit in the passenger seat to use the door switch for that one) looses it's "one-touch" down function occasionally, always immediately after startup. Sometimes it'll come back later, without even restarting the car.
I'm not sure if it's a switch or control module issue at this point. I suspect the switch, since normal up and down work correctly. The switch "feels" fine, but that doesn't mean much.
One other question: is the electronic box that rests inside the armrest behind the door panel for the driver door only, or the master control for all windows and locks? Basically, I'm wondering if I can just swap the passenger and driver side modules to see if it makes any difference.
