Power Window Motor/Regulator
dndwolf
Car: 1996 Infiniti I30t
Anyone out there that can give me advice on the difficulty of swapping out a power window motor vs swapping out the whole motor/regulator assembly? (I'm working on a 1996 I30t). I have a complete aftermarket assembly available for ~ $70, or an OEM regulator only for $56. I'm inclined to go with the OEM regulator to ensure a good fit, but need to know if it's a pain in the a$$ to swap out the motor.
Thanks!
D_roc
Car: 2001 Maxima 20th aniv edition
i'd go with the oem one, and replacing it is a little bit hard and takes some time. before taking it apart take a good look at a service manual
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Replaced the motor on the driver door on my 95 Maxima
I was not too bad
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
I don't know price wise what the difference is but when I replaced mine on my 3rd gen (I've done all but the front passenger side one) I just replaced the whole unit because I wasn't going to take a chance.
Oh and I went with aftermarket but they were dubbed OEM replacement. In other words they weren't "NISSAN" products but they were OEM replacements off a different brand and they work just fine.
As far as difficulty mine were VERY easy to do...but I don't know if the 4th gen's are as easy. But if they are set up the same you shouldn't have a problem.
NutriaforBreakfast
I hear its good to put a light coating of grease in the channelstoo.
PBfrEAk
I didn't but I'm sure it couldn't hurt anything!!
Professor`
Car: 2000 Nissan Maxima Sunlit Sand.
i just replaced my right rear motor in my 2k maxima, very simple, 4 bolts on the track, 3 on the motor, 2 on the glass,but even with the new motor, switches, it still dident solve my problem......window goes down, but wont go up.only goes up if i use a sep battery on the motor itself.
