SilviablhS14 »
https://forums.nicoclub.com/silviablhs14-u178400.html
Wed Apr 06, 2011 9:52 pm
So here's the problem. After I bought my car a year ago I had to change the window motor and the amp motor. Earlier today I had the windows down and went to roll them up and the same window that gave me problems a year ago. I took the door panel off and got the window up and pulled the amp. The amp looks good and doesn't look like there are any problems with it except there is a piece of copper showing through the green mat. There is also a clicking noise coming from inside of the door panel. I think it might be the window amp that the clicking noise is coming from does this mean its bad.
I found a website that sells the window motors brand new, not remaned, for under $50 but the only thing is that the only one they have is the one for a 89-94 Maxima. Will this work? It looks like it is the same thing and has the same kind of connectors.
I also fixed the driver side window switch so I don't think it is that.
