evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Feb 22, 2007 6:38 pm
it's wedged in, you have to remove the correct bolts, I seem to recall there were 3? and then you have to wrestel it out while supposring the galss and prying it from between the door shell and the windor regulator, it really is a pain in the butt, also easier if you go ahead and remove the seatbelt retianing brackets and bolts and get the whole door panel out of the way
