Sushibandito »
https://forums.nicoclub.com/sushibandito-u133627.html
Wed Apr 07, 2010 10:56 am
I did a lot of searching for this, but couldn't find any info since it seems like an unusual problem... The door I previously had on my hatch was dented by the previous owner, to the point where buying a clean door shell was the most cost-effective.
So my local shop guy swapped out the guts and put the new door on. The window in the door came off my old door. The body lines are pretty good match, maybe 1/16" off (as you can see on the rear fender), but hardly noticeable. The issue now is that when I roll it up, it comes up high enough it won't shut without catching on the little lip up top. It's at least 1/4" too high. This isn't an issue now, but by summer time I would like to have the option of rolling them down, and simply rolling them back up.
So I can't find anything on adjusting the height, I looked around and I can't located anything the looks like it raising/lowers the window inside the shell, any help? It's a power door, my hatch is a 92, and it appears the door may have came off a 89-90.
