Power window failure
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
G35bobliz
Car: 2004 Infiniti G35 Coupe
Complete disconnect on driver's side power window. What do I need to do to correct this?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You may need a need switch, could be the motor. You are going to have to do some investigating to see what has failed.
G35bobliz
I stripped the door down today and found brushes were siezed in the electric motor of the window mechanism. It appeared that there was an excess of grease around them which had dried up and siezed them so they were not making contact. A little penetrating oil (WD40) degreased the armature and everything works fine now. A rather time consuming exercise but definitely worth it to fix the problem and not have to take it in for repair.
audtatious
Nice job. Did you happen to take pix?
joe603
Car: 2014 Durango R/T
+1, nice fix! Most would have replaced the window motor.
G35bobliz
We were too busy figuring it out to think of taking pix! Time and patience paid off and avoided replacing motor unnecessarily. Appreciate the feedback.
Return to “G35 and G37 Interior, Exterior and Audio”
