tonynalli »
https://forums.nicoclub.com/tonynalli-u14578.html
Wed Mar 10, 2004 6:17 pm
if you want to replace the window regulator then you will have to remove the widow. it will most likely take two 10mm nuts. and once that is removed then it takes 4 10mm nuts. and then pull it out. the main problem that i had with mine is that there is a rubber coupling(or thats what i call it) that holds the main gear on to the slider. if you try to glue it together it wont work. i have tried many times. i jsut replaced it with a maunal regulator. luckally it was on the drivers side so it really doesnt bother me. but if you want to just have it stuck up, wedge a piece of paper between two gears becuase duct tape will leave a sticky residue. paper can be removed ealisy.
