Power Window AS fuse
kensf49
Car: 1997 J30
My voltage regulator went out and caused an over charge of the electrical system taking out several systems. I have fixed everything except the Power windows. The power window As fuse keeps blowing and ideas on what is causing it? My local Infinite parts dealer suggested I replace the window circuit breaker. I have a replacement but cannot locate it. Anyone know where it is? confused
I guess it needs to go to the shop, but the window is down and I need to get it up now (bad weather) any ideas?
Modified by kensf49 at 2:56 PM 1/10/2009
Modified by kensf49 at 2:57 PM 1/10/2009
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Have you read the FSM AKA Service Manual?
I would read this: http://www.nicoclub.com/FSM/J30/1997_J30/el.pdf as it pertains to your problem, Go to LOCATION OF ELECTRICAL UNITS Then go to page EL-268 and you will see where the circuit breaker is located.
Or you could always ask your Infiniti deaer where it located because they have a program called Nissan FAST which you can get as well but it shows them a picture of where the part is and how much it costs and more.
But when you solve your problem with the windows I would read the rest of the service manual: http://www.nicoclub.com/FSM/J30/1997_J30/
Good Luck and welcome to NICO
kensf49
Car: 1997 J30
Thanks for the help. I'm putting it to good use this morning.
jssomers
Car: 2002 Infiniti G20
Hey Kensf49,
I'm having a similar problem with my 2002 G20, can't find where I'm loosing power to the front passenger as well. I also had my window down and sport some plastic for a couple days. However, a friend and I hooked up some speaker wire directly from the battery to the window motor, and it rolled right up.(rolled down first but we switch the neg and pos wires and it went up) Worked for a temporary fix.
