Power Window and Blower Probs, Just Multimeter Tested
dephrag
Car: 1995 240sx
Hi Guys
Just actually found the forum and it seems to be more informative than most of the other nissan boards.. So maybe some pro's can give me some advice.(I've got a '95 S14)
My passenger side window is havin some issues. I've read about the driver side issue, but nobody seems to have solved this one.
The passenger window won't roll DOWN from the passenger controll. It WILL however always roll UP. The driver side control will SOMETIMES roll the window up and down, and when it doesn't, it can be fixed my holding down and wiggling the passenger side switch up and down.
I picked up a multimeter today and attempted to see if i could use the thing.
I uplugged the Pass. switch and stuck it in the connector that looks like:
I plugged the multimeter into all and found power in bottom 2nd from left. It was reading 12.2 and slightly less when I rolled up the window. Same with from the driver side. When I tried to roll it down from the P or the D side it automaticaly went to 0. Does this help diagnose the prob at all??
The other prob:
My Blower just recently stopped working. (Not the resistor, I've already been through that). It suddenly stopped working on ALL levels. I plugged the multimeter into the power connector on the Blower and it read a solid 12.2 when I turned the fan on. Is that pretty much confirmed the blower motor is dead?? I was attempting to take it out, but it looks like I might have to get the dash off to do so!!
Thanks in advance,James
NISTECH
Welcome to NICO James.
You have comfirmed you have voltage to both but you have not comrirmed you have ground which is pretty much what the switches control. Unplug your blower motor and check for ground on the wire that wasnt power when you turn the fan switch to number 4. You should have a solid contact to ground. If you do then yes the motor is toast. If you dont then you have a problem with the switch circuit.
On your window it sounds like you have a bad switch. Guessing by how you get it to work I would say its your passenger switch.
